Hello Folks, I need some help, I need recommendations on how to implement a grid layout of WS2812Bs. Problem is my grid is a serpentine layout with the first row starting from the right and going left, instead of the normal way where the first pixel is on the left and the string cascades right. Also on top of having a backwards serpentine layout, I also don’t have a perfectly square grid, the top row is shorter by one pixel on either side then the rest of the grid.
I’ll try to lay this out ASCII style:
Have a look at how @Garrett_Mace did XY mapping for his cool shades with a odd shaped grid.
Also, have a look at @Aaron_Liddiment 's custom matrix library stuff. His LEDLatrix can probably reverse your backwards serpentine in code, or at least give you some pointers.
And his LEDText does text scrolling.
I put 8 strips of WS2812B pixels 15/strip on an umbrella and I’m treating it like a matrix. Even though it’s straightforward (8x15), it starts at the bottom left. The adafruit neopixel matrix library has this option and uses text in the example. I just ended up mapping it out since I couldn’t find a way to tag one of the corners as the starting point; the RGBShades xymapping was really helpful.
I’m still figuring out my sketch (mainly due to wanting to run when I’m just learning to walk) so these tips are SUPER helpful.
Thats great, its hard to find answers to these strictly using google so thats why i asked. Ask and you shall receive! lol thank you very much for the info. I’ll give it a try.
I’m so happy someone gave me the clues. Once i saw that code I realized all i had to do was remap the LED order in a different table that the main function “XY(x,y)” would use to correctly return the correct LED address. It was so simple I don’t know why I didn’t think of it before. but I’m glad I asked. The ShadesMatric helper code took care of my reverse order and odd grid shape. Pro Tip: Laying out the actual shape of your matrix in the table array helps you visualize your design and helps you see where the pointer should point. Now on to getting the scrolling text to work.
Ok so I’ve been playing with the LEDMatrix and LEDText libraries, they haven’t been updated in a year seems he hasn’t been maintaining the code much recently. but, I see a function called SetLEDArray and you pass it a struct CRGB. I’m guessing this is where I would create a custom LED array table with the remapped addresses? but I’m not sure how I set that up. Do i declare an array with a name and then pass that name in to the function somewhere in the setup loop?
