Hello friends, Iam a newbe… an here is the million dollar question
is there some guide for coding , to understand what iam doing
Have a big projekt for my rc helicopter.
My setup is a Arduino mini pro with an sparkfun usb breakout.
for testing a circle with 16 leds.
have many questions, to control specific leds on one comand or something.
Hello Jason!
yes i have allready tryed this. it works perfektly.
my problem is i have 5 meter stripe with 60LEDs per Meter
wich is in order of the helicopter contour. Imagine ?
for example:
i want to put in a white dot light wich run through the stripe from the front to the end of stripe. LED on , next LED on, last LED of. you know ? But for 300 LEDs i need a routine.
a next important thing i need to know is,
is it possible to control a partial area with one command to set 10 LED streak into blue for example to turn of to turn on or strobe?
Great, so the next step is to start modifying the examples, and learn basic C syntax, if you don’t already. Even if it’s not exactly what you want, you’ll need to understand the examples, and how to extend them. Crawl, walk, then run.
