hello guys, how are you? i have a little problem whit a 3D print. I have a Wnahao i3 3d printer, I am very happy whit that printer but last night this happened. the settings are:
Material: ABS verbatim
Speed perimeters: 20mm/s
infill: 20%
Infill speed: 40mm/s
Retraction: YES
Layer Z: 0.2mm
temp: 235/90
extrusion multiplier: 105%
cool fan: OFF
My printer have an enclosure.
software: repetier
As can you see in the photo, the gap between the primeters ans the infill is to high,
and that marks in the bulb of the lamp y don’t like
It’s the first time i see that
Can you help me to resolve this
Can’t see the pic, repost it please.
You’re definitely printing too hot but what’s your infill overlap percentage set to in your slicer?
@Adam_Steinmark ok Man. Thanks for the comment. Look the overlap. I never change that setting.
That should be fine. Have you properly calibrated your extruder? Try this method: https://www.youtube.com/watch?v=YUPfBJz3I6Y
Ok man. Thanks. I will do that.
I second Adams comments, looks like printing to hot.
Suggest try lower temp first, 15% infill overlap is normally plenty. Infill gap may go away with heat reduction, I suspect it is radiant heat trapped in that V area of the print causing that area to cool unevenly. Warping sideways from the heat trapping geometry of the object.
