Hello guys,
Total noob here. I am using ESP32 with 8X8 RGB WS2812 matrix. But whenever i am running sample code to light the LEDs, I am getting the following error message:
Arduino: 1.8.5 (Windows 8.1), Board: “ESP32 Dev Module, Disabled, Default, QIO, 80MHz, 4MB (32Mb), 115200, None”
D:\Arduino_ESP_Support\sketch_jul30a\sketch_jul30a.ino:15:0: warning: “BRIGHTNESS” redefined
#define BRIGHTNESS 96
D:\Arduino_ESP_Support\sketch_jul30a\sketch_jul30a.ino:9:0: note: this is the location of the previous definition
#define BRIGHTNESS 64
In file included from D:\Arduino_ESP_Support\sketch_jul30a\sketch_jul30a.ino:5:0:
C:\Users\Shri\Documents\Arduino\libraries\FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.008
pragma message “FastLED version 3.001.008”
In file included from C:\Users\Shri\Documents\Arduino\libraries\FastLED/FastLED.h:68:0,
C:\Users\Shri\Documents\Arduino\libraries\FastLED/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
pragma message “No hardware SPI pins defined. All SPI access will default to bitbanged output”
In file included from C:\Users\Shri\Documents\Arduino\libraries\FastLED/FastLED.h:51:0,
C:\Users\Shri\Documents\Arduino\libraries\FastLED/fastpin.h: In instantiation of ‘class FastPin<32u>’:
C:\Users\Shri\Documents\Arduino\libraries\FastLED/platforms/esp/32/clockless_esp32.h:22:52: required from ‘class ClocklessController<32, 60, 150, 90, (EOrder)66u, 0, false, 5>’
C:\Users\Shri\Documents\Arduino\libraries\FastLED/chipsets.h:468:7: required from ‘class WS2812Controller800Khz<32u, (EOrder)66u>’
C:\Users\Shri\Documents\Arduino\libraries\FastLED/FastLED.h:104:52: required from ‘class WS2812<32u, (EOrder)66u>’
C:\Users\Shri\Documents\Arduino\libraries\FastLED/FastLED.h:298:39: required from ‘static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2812; unsigned char DATA_PIN = 32u; EOrder RGB_ORDER = (EOrder)66u]’
D:\Arduino_ESP_Support\sketch_jul30a\sketch_jul30a.ino:261:63: required from here
C:\Users\Shri\Documents\Arduino\libraries\FastLED/fastpin.h:207:2: error: static assertion failed: Invalid pin specified
static_assert(validpin(), “Invalid pin specified”);
exit status 1
Error compiling for board ESP32 Dev Module.
Please help me out if you know how to deal with this error.
