Hello!
How do you set up order of operations? For instance cutting out the inside parts of a word/name before cutting out the outside line/edge?
Thank you so much!
Hello!
Thank you so much!
@Aaron_Russell besides each operation there are arrows, that will change the order. Look at this video as I show that specifically https://plus.google.com/+ArielYahni/posts/ABi6FT9hyCB
Thank you! I thought there was a way to do it with the color filter options?
Nope, color is used as a filter only.
You can use the color filter to select what fill- or stroke-color get utilized for the operation.
So you could take a single item, create 2 operations with it, filter one by fill color, the other by stroke color and thus control the order (using the arrows @Ariel_Yahni_UniKpty mentioned you can also re-order them)
You cannot have it order it’s operations by color automatically. though…
