Hello. I am attempting to use FastLED and Button Master library (renamed Button) and
Hello.
I am attempting to use FastLED and Button Master library (renamed Button) and different then the Button library found in library manager to utilize 4 buttons to trigger different patterns. My code thus far:
At the bottom of the code I have populated some attempts (none are working) to get the strip to do something when a button is pressed, for example:
if(myButtonD.wasPressed()) {
leds[1].setRGB( 0, 255, 225);
FastLED.show();
delay(30);
//D was pressed so set a variable or do something
Any help appreciated at getting these 4 buttons working.
Un-comment line 63 and 71 and then try updating your button sections to something like this:
myButtonA.read();
if(myButtonA.wasPressed()) {
gCurrentPatternNumber = 0; //confetti_GB
myButtonB.read();
if(myButtonB.wasPressed()) {
gCurrentPatternNumber = 1; //sinelon_B
etc.
The gCurrentPatternNumber number comes from the order and position of patterns in line 63.
Also, avoid using delay() as it could cause the program to miss reading a button push.
Hey Marc,
Thanks for the response!
I was able to get it to work. I also had to uncomment line 62.
Thanks for all your help.
Alright, great to hear @Andy_Smith1 ​!
