Hello.
I am new in this group, and I have a question.
I haave Coreldraw Laser, but it is in Chinese, is it possible to get an Englisch version?
Thank you< greetz, Kees
you might be better off trying an open source software, try K40 Whisperer or Lightburn, they should work with the stock controller or laserweb if you upgrade it.
@Kees_Moret you can change the language. Look for the small pink icon in the windows system tray at the bottom and right click it. There will be a language selection option. As Joe said, your other option with the stock controller is to use K40 Whisperer.
Sorry for my late reaction…
Thank you both, I find out…
Works Lightburn easyer then Corel?
Thank you already…
@Kees_Moret light burn is much better but it requires that you upgrade your control board. Corellaser is useable but it’s quite buggy unless you get a more current version of Corel Draw, which is pricey. K40 whisperer is a better control option with the stock board but you need to design in another program like Ink Scape.
@Nedman Thank you for your advise…
I will try it out.
