Well, that’s good. We can say your circuit is fine, so that’s a plus.
Using a LiPo, I prefer to not run a large number of leds off them. Depending on the pattern I’m using, I don’t generally like to go much over 60 pixels. I try to keep it under 1A draw. Those batteries are volitile, so I like to be gentle on them. I’ve never made a project with multiple power supplies, so I can’t give any advice from experience, what I’ve read always says it’s a better practice to get it from one power supply if possible.
The resistance of the strip probably isn’t the issue anyways. I’ve never had 1 meter cause any issues with resistance.
Personally, I would drop the brightness down to 50, just to ensure the program is working. Then figure out power options.
Alkaline could be a good option as well. Not rechargeable, but they seem to work better at higher current rates. It can be safer too. If 4 alkalines get put in your nimh holder by accident, you’ll blow the leds from too much voltage.
Since you seem to want to power this from a battery, I would highly recommend doing everything you can to lower your current draw. To provide more amps from portable sources starts getting pricey.
There are options, however, such as portable power banks (think portable phone chargers), depending on your size and cost limitations. You’ll likely have to modify a usb cable to get your power, but some can supply up to 6A at 5V from multiple usb ports (up to 2.4A per port). But it’s another option.
Can I ask some questions?
What controller are you using?
What capacity LiPo do you have?
Are you powering the leds from the board?
If you are powering from the board, what power pin are you using?
