Hello, I had a question on fuses. I want to out a fuse on the plug coming into the printer and I am not sure what fuse I should buy. I was about to go buy a 20 amp one when I realized that my breaker box would trip before the fuse did, that is obviously too large.
What size fuse should I use. I am running a 12V RAMPS with MK3 heated bed from RAMPS. Pretty standard setup.
Thanks!
The breaker is what a 10amp 120v? It has its own protection verses faults. What you want is a fuse on the dc side to handle the load that the printer is using between the psu and the input into the controller or equipment. On the ramps you have two power inputs one rated at 5amp and the other at 10-11amps, I have replaced my poly fuses with automotive fuses.
3A at 120V is ample. Amps=Volts/Watts
