I had some questions about using DMA on the Teensy 3.6. Are the DMA pins the same as the teensy 3.2? And if i wanted to use PORTDC (Pins: 2,14,7,8,6,20,21,5,15,22,23,9,10,13,11,12) as well as a WIZNET820io (SPI on pins: 9,10,11,12,13) would this be possible or would the DMA pins affect the SPI connection?
Thanks for the reply. I checked out the github and saw that someone has modified the library to work with the 3.5 and 3.6 so hopefully that works all well and good :).I might just try wiring it up and see what happens :), Cheers
