Hello!
I have a question. I am still working on sending and receiving binary data with chilipeppr and the serial port json server and I was able to make some progress. I can send binary data to the node and it responds correctly.
There is just a small issue:
When the node sends a 0x0D byte I receive a 0x0A. In the code of serial port json server in the file serialport.go when I do a print of the received data in the function reader() it is already incorrect. So, if I understand correctly it gets already written to it this way by goserial?
0x0A is \n newline character and 0x0D is \r return character so I assume there must be some byte to string conversion somewhere but I am unable to find where this happens before it gets written to the reader() function.
Any help would be very appreciated because I am kind of stuck. Thank you very much!
Regards,
Bastian
