Hello!
I have just set up my Eleksmaker and flashed Gerbl1.1f on to the nano.
I have been using LaserWeb this morning but generally messing with settings and not sure if they are even in the “ballpark”.
What settings should I really be using for:
X and Y max rate (mm/min) $100 and $101
2 ) Acceleration (X and Y). $120 and $121. -
What is the “Cut Rate” option? (range 1->50,000)
Laser Diameter…how can I actually measure this…or is it a bit of a “0.1mm as a guess”?
On the setup…if I am using Gerbl…do I set “S PWM max Value” to 1000?
Thanks for any help!
