Hello! I just wired up my Azteeg X3 V2 with the latest marlin firmware, and I cannot get the steppers to behave correctly. They are set to 1.5A (2X vref - .75 V) They only move a step backward and move forwards loudly and with little torque. They have great holding torque, though. See attached vids
https://youtu.be/v9GjXS_3KYQ
https://youtu.be/Gqhv-k7Wrrg
I think only one of the coils is working. Check the wiring to make sure both coils show continuity back at the board with a multimeter.
Also the max current is 1.5A, but you don’t need to run at max. Try 1.2A to start. Go up if you loose steps… And down if you have excessive heat at the stepper or driver.
Ok, Thanks! I’ll go check now and turn down the current. I turned it up because I thought they had trouble moving the carriage.
@Eclsnowman I checked the connections, all good. I forgot to set the steps per mm
Hey, anyone know if there is anything I need to change in the firmware to make this work? They move forward a bit loud (with little torque) and sometimes don’t at all. They never move backwards though, they just move a step back no matter how many mm’s I say.
@Stefano_Pagani any chance it is looking for limit switch input? Maybe you could home, or make it think it homed… Then jog both directions?
Oh, it could be that, ill go buy some switches
