hello,  I need to drive a 48x96 px arrays of APA102 and I would
hello,
I need to drive a 48x96 px arrays of APA102 and I would like to know what is the best device to do so.
The whole array take 18kB of memory so if I use an Arduino, I’ll need a Due (because of sRAM amount).
But what about update rate ?
I guess I can put about 300 leds on one bus, could I drive 16 bus with a single Due ? Or how many boards would I need to drive 4608 pixels ?
Or which board would you recommend to me ?
thanks for helping
use a teensy 3.1
thanks for the quick answer.
Are you saying that it won’t work with a Due ?
It has a 32bit processor, quicker than Teensy 3.1.
I need an ArtNet server to control the array so I was thinking about using an Arduino with an Ethernet shield, because it seems to me to be easier than the Teensy 3.1 + WIZ112 Ethernet module.
For Ethernet driving 4600 LEDs, definitely avoid the W5100 chip (the one on the normal Arduino Ethernet shield). It’s got a ton of SPI overhead. Every byte of data takes at least 4 bytes on the SPI bus. The W5200 has a much more efficient burst access mode, so you can get most of the SPI bandwidth. Luckily, Artnet uses UDP, and the W5200 is pretty efficient when reading the whole packet into memory at once.
Unfortunately, you’ll have a hard time making this project work (at fast update speed) with a SPI port shared between the Ethernet and the LED output. Ideally, you want 2 different ports to bring the data in and also stream it out, hopefully simultaneously.
Here’s a project I made several months ago for Freescale at Maker Faire, with 4320 LEDs, updating with 30 Hz video.
An updated version of that code is available here:
Updating this many LEDs at 30 Hz or faster is quite a challenge.
thanks for the feedback,
what a nice panel you did !
I need something like this, but flexible :slight_smile:
I’m not married with Arduino at all, I can use anything else, I’m just looking to the easier in the price/time balance :slight_smile:
I understand the SPI port sharing issue, and I guess I will have the same with the Teensy since there is only one SPI bus on it.
So I’ll take a look at Raspberry Pi on which the Ethernet port is shared with USB and not with SPI.
But FastLed doesn’t easily work on it, isn’t it ?
FastLED doesn’t run on the Pi. But depending on how soon you need to build your display, @Daniel_Garcia did mention he was interested in supporting the Beaglebone (it has PRUs—Programmable Realtime Units—that you could port FastLED to.)
nice to hear that FastLed will increase supported platforms !
but I need to make some tests really fast, and I think I will go with PixelPusher board.
pixelpusher is based on teensy , and is not bad at all
