I tried to use the autolevel widget with an Inventables Carvey.
I have the contacts wired up correctly and as long as I only try to run a test probe with the autolevel, it works.
When I run the auto-leveling, it stops after the first point, and permanently stucks paused.
Tried to find out as much as I can from previous discussions, but none of them offered a solution so far.
I am using the Jpadie workspace.
I also can see an error in DevTools.
My guess is that Auto-Level did not get updated to support Grbl 1.1 yet, so would you be up for forking and editing the Javascript code? I doubt there are too many changes to make it work.
Autolevel is up to date with grbl1.1. I’ve not seen that error before but I did make some changes a week ago in some code that is not exposed. Possibly some odd gremlin. I have some time in the next hour and will take a look.
I tried it today and am having the same issue as Adam. if I go to jpadie, it will run but pauses half way through the process. Anyone else try it lately
