Hello, I'm just getting started with an LED project and I've already hit a
Hello, I’m just getting started with an LED project and I’ve already hit a snag. I’m using a Teensy 3.2 -> OctoWS2811 board -> WS2811 leds. When I run example code from the OctoWS2811 library everything looks great. All of the colors are in order and everything. When I try to run sample code from FastLED’s OctoWS2811demo I just get flickering garbage. I’m using the latest FastLED library. Is there some setting that I haven’t found yet? Any clues will be greatly appreciated.
Have you tried any other examples? I always start with the demo real 100, to check everything works.
Found my mistake… was plugged into the wrong ethernet jack. I was plugging into the 1st jack, when I should’ve plugged into the 0th one. :slight_smile: The Octows2811 code was pushing to all leds, so it was fine, the FastLED code was only pushing to one. Alright, things are blinking so time to get coding! Thanks!
I can’t wait to see what you make/put together! Be sure to come back and show us photos/videos :slight_smile:
