Hello!
I’m trying to use the laser fill path command, but after setting parameters and clicking generate it gets to 50% and won’t finish. I’ve tried several times using different types of svg files and even after waiting 10 minutes it is still only at 50%.
Any ideas?
Screenshot of your file? This could be related to you vector been very tiny paths which LW does not like
Wait longer? I’ve had projects with lots of small paths that took 30+m to generate
So it went through, but it took nearly 35 minutes to generate. Is there any way to speed that process up? Faster computer?
Fix tiny paths is by far the best solution
Thank you!
Also you could try increasing gcode generations threads https://plus.google.com/photos/108534149229055139394/albums/6472082736165471089/6472082743081521378
