Hello.
I’m using a CNC 320 mm M6 stainless steel lead screw & anti-backlash delrin nut from this store for the z-axis.
http://www.qtecstore.com/pages/leadscrew_nuts/6mm_leadscrew_nuts/6mm_320_leadscrew_nut/page.html
The problem is, when i gave a 20mm tower calibration print, the print is not exactly 20mm height (it is around 19.65mm). I also tried adjusting the backlash nut which is provided with the delrin nut but the results are the same! I am using 3200 steps/mm for z axis.
Any help will be appreciated.
Thanks in advance
