Hello. Im vj chuck
Help me…
I want to control LED strip of 36m(30pixel/m.ws2811) by using Madmapper(vj software_artnet).
I merged Arduino uni and DMX Sheild and fixed code that vjspain made to connect OpenDmxEthernet, but failed.
I think that what I’ve done is same as vjspain’s hardware, software and Arduino set up.
(the below URLs that I referred)
http://vjspain.com/blog/2013/11/19/proyecto-dimmer-con-arduino-para-tiras-de-led-digitales/
I need to figure what the problem is and need your help.
There is something that I cannot understand.
As far as I know, DMX is able to use 512’s channel. So, I am wondering whether DMX can control 170 RGBpixel per 1 DMX or can control more than 170.
http://www.showjockey.com/product.php?id=196
If I use the device in above URL, is it possible to be controlled many ports(Port x170) by madmapper or vj software?
Seriously, though, starting simple then slowly adding pieces lets you see/identify exactly what step things start failing and how.
