Hello. I'm working in my LED clock.
Hello.
I’m working in my LED clock.
I finished the basic features but I’m blocked with the extras. I had a few ilumination modes but I want to add a new one.
I had a WS2801 strip with 60 leds. I show the hor with 3 red leds and minutes with a blue one. I want tha the seconds left an stella, but i have no clue how to do it.
All my tries had been wrong.
Here is the main program: https://gitlab.com/dardoware/Arduino_LEDClock/blob/master/arduino/ledClock_sam/ledClock_sam.ino
And here is the file where is the function that sets the values to the led array: https://gitlab.com/dardoware/Arduino_LEDClock/blob/master/arduino/ledClock_sam/modo_estelas.ino
I’m sure that I dint’t something completele wrong.
Any clue about how to achieve my goal it’swellcome.
Hi Samuel, I tried to look into your code but got totally lost between the Spanish and the number of files you use. Excuse my very poor Spanish but I assume you want the second LED to twinkle like a star !
To achieve this you will simply need to update that LED faster than once per second.
Do you want a soft slow constant update like a linear ramp-up and ramp-down or a sine wave for a softer effect ?
D you want a more random blinking that emulates a real star ?
You will need to play with the number of update per seconds that will achieve the final effect you want.
I would also suggest that you could use something like a softer movement of the seconds LED using the following antialiasing example created by Mark Kriegsman…
From a fellow clock maker…
https://plus.google.com/106626345342202981932/posts/SM62KcSTgon
Thanks for your fast reply.
I don’t care about a linear ramp or a sine effect, I’ll test both anyway. Now I get 55 updates per second.
Now I have a three (simple) visualization modes without antialiasing, and it’s definitively somethong that I want to test.
I’ll try it later today.
Thanks!
I was studing the demo that you recomended, but I don’t know how to do it.
I refresh the leds at a given rate ie 16 times per second, and i want to dim one led 1/16th of it’s britghtness each iteration an lit the next increase the brightnes by the same amount.
I know how to do it with HSV colors, because it’s very simple reduce only de value of the color, but i had coded my color palettes with RGB values and I don’t find an easy way to reduce the brigthness of a RGB color.
I’m sure that had to be an easy way to do it. I though in create an CHSV auxiliar variable and the assing it to my pixel, but I didn’t found a way to convert a CRGB color to CHSV one.
Hi @Samuel_V.G ,
I do not believe that he library supports a RGB2HSV function ?
I remember some discussion about the possibility of introducing that but maybe @Mark_Kriegsman can confirm this ?
There is of course, color math operations available for the CRGB data.
Look here…
We do have an approximation for hsv2rgb; it’s like this:
CHSV hsv;
CRGB rgb;
rgb = hsv2rgb_approximate;
See detailed discussion at https://plus.google.com/112916219338292742137/posts/Rxx6RpgpSr2?gl=us
