I spent 3 hours on search some info about my issue when led strip just blinks by random colors with random leds, when I dissconect arduino it remember it state.When I connect arduino back, leds start their chaos back. When I connect a ground wire from the leds’ DC source to the arduino my led strip stops working at all. What shoud I do? Thank you!
So when you connect ground on the LED strip to ground in the arduino it stops working? That’s strange as there always needs to be a common ground between everything.
Wait, I should have noticed this earlier, what version of the pro micro do you have, the 5V or 3.3V? (I’m guessing the 3.3V). The LED strips work best with a 5V data signal.
@marmil Arduino pro micro powered through USB port, led from the wall, when I’ve tried other libraries result was better but still bad, some diods doesn’t work and it’s not because they are dead or smth. All mmy tests went without connected ground to the arduino, at east it makes signs of life
I found a library (https://github.com/cpldcpu/light_ws2812) every pixel is working now. From the side of the first pixel I’ve connected BI and DI to the Arduino pin without conecting ground to it. From the side of the last pixel I’ve connected 5+, GND and BI to GND as well. Seems like it works
