Hello led users! I have a question about the nano arduino vs teensy 3.1.
Hello led users! I have a question about the nano arduino vs teensy 3.1. Nano is cheaper than the other. What is the benefit for fast led libraries out there? What is pro and con? I think nano should be ok because they are arduino compatible 328 IC. I dont understand why teensy 3.1 is popular. And its pricy. I m curious, Which is your best recommended?
Nano is great for small to medium projects (I own ~15 of them).
Teensy is great for larger projects as it has a LOT more of everything, namely CPU, RAM and Flash (I only have 1 of these).
That being said, I’m looking to migrate FROM the Nano to the Pro Micro. The reason is that the Nano:
  1. Uses mini-USB connectors, which are not as common as Micro USB connectors that cell phones use.
  2. Uses FTDI chips for serial connection. Some of these are clones and there are serious driver issues with them (Google ftdi rant).
Nano and Teensy 3.1 are my gotos actually, i like them for their size.
Nano is fine for basic projects, all my LED stickman suits and furniture items use them.
for my large projects I use teensy 3.1
There’s also the $12 Teensy LC, which is cheaper but not as powerful as a Teensy 3.1, but still has higher specs than the Nano: https://www.pjrc.com/teensy/teensyLC.html
Also, don’t forget the constant reminders from Daniel: often the microcontroller is one of the lower expenses of a build. After spending money on LEDs, batteries, etc, why skimp on the microcontroller?
Don’t overlook the $8 Beetle http://www.dfrobot.com/index.php?route=product/product&product_id=1075&search=Beetle&description=true&category_id=48
(Also available with Bluetooth for $15! http://www.dfrobot.com/index.php?route=product/product&product_id=1259)
Just be aware that the teensy lc is not yet fully supported. I want to burn all cortex m0 based devices to the ground sometimes.
