The best solution IMHO would be to re-drill the holes larger and use those OpenBuilds eccentric spacers - they would allow you to fine-tune the tension in the wheels. I like that many of these cheap printers are built using the V-slot extrusions but none of them use the eccentric spacers despite them costing less than $0.40 each retail.
@Jakab_Gipsz I don’t think I understood. Do you want me to rotate this plate 90°?? The wheels are already too wide, so rotating the plate will make them even wider.
@1111125 Good luck, should be a fairly easy fix. Just make sure to drill the holes just the right size so that the eccentric spacers sit solidly on the plate.
@Petr_Sedlacek about that, I think it will be too risky to drill only the other side. My measurements show that it will still be okey, and the offset won’t be too big. I hope it would work.
Is your tevo kit mostly plexiglass, or mostly 3d printed material. I was just reading about quality control issues with the plexiglass version, and to fix it you should be able to buy a fix-it kit made from 3d printed materials.
@MidnightVisions it’s the plexiglass version, I think I am okay with it. There is no need to replace it or buy any additional kits. Maybe I will try the additional Z rod kit in the future, or create my own one with a stepper motor, laser muchine, and few other materials.
@Richard_Jones Not sure that’s a cost effective upgrade. A cheap linear rail might not be that great and a properly adjusted V-slot slide is very solid.
