Hello, Thanks for the great app, it was much needed.
Hello, Thanks for the great app, it was much needed. I have yet to get it working though… I am unable to establish a bluetooth connection between my printer and my smartphone. I’m not sure what’s wrong. I have set the baud rate of my firmware and the bluetooth module to 115200 and everything is wired up well.
I don`t mind using USB but, the issue with using usb is that the battery of the smartphone will eventually run out, no??
Ok, the phone actually charges while connected to the ramps board.
@Ethienne_TheHackerAr it really charges ? I never saw this before. Usually I recommend a tablet/phone with dedicated power port. Bluetooth has a higher latency than USB which an lead to stuttering when doing high resolution prints. If you send me the logs I might be able to see why bluetooth fails (enable debug option first).
no, it doesnt charge…unfortunatly
Sure, I can send you the log after re testing
