Hello, wondering if I can get a bit of help.
Just updated arduino 1.0.6 and teensyduino 1.2 on a teensy 3.1 and now fastled does not compile, same version (2.1) that I was using before on the old version. Same thing happened when I did a fresh download of everything in a new directory. Reverting back to the old version now…
http://pastebin.com/AsGyYm7C
Make sure you have the most recent version of fastled2.1 (and that you don’t have stale copies of the library around)
Also - see where it says “This report would have more information with
“Show verbose output during compilation”
enabled in File > Preferences.” In what you posted? Please do that in the future - gives more information that may be helpful the next time
Thanks… though I just downloaded the zip of 2.1 branch from git just now, so I’m pretty sure it’s the latest version…
Just seeing if this was a known error or if it’s something wrong on my end. I’ll see if I can figure it out.
I’m assuming you mean 1.20, btw, for the teensyduino version (1.18 was a recent version).
I suggested checking the versions again because I’m using this exact setup at home (the 3.1 is my preferred platform) - and the error you are getting describes a thing that Paul changed with 1.20 that I had to merge a fix in for a while ago.
Yeah - you’re not using the most recent version of 2.1 - the line numbers in your error messages don’t line up with the code that’s in the repo.
