Help! I said I would make an exhaust box for my friend who purchased
Help!
I said I would make an exhaust box for my friend who purchased my old K40.
I need the dimensions of the exhaust opening brackets that hold the fan.
Unfortunately he is unavailable to check the dimensions.
Thanks!
Sorry I am in Singapore so can’t measure my k40 at home. What about thingiverse https://www.thingiverse.com/thing:2272337
The inside horizontal width of the brackets for mine is 245mm. The vertical distance from the bottom bracket to the top of the opening is 85mm. Let me know if you need anything else.
Thanks guys for helping out!
Are you going to do a straight out vent tube connector or an angled 90 deg one?
I am going to have the hole but it will be up to my friend if he wants a 90 or not.
I printed and used this one https://www.thingiverse.com/thing:628269 Reinforced it with epoxy and fiberglass and it is bullet proof. It has a file with dimensions but you will need a program to view it.
