I can see smoothie com port ,can also access the sd
but i can’t connection Pronterface
What mean led 2 3 flashing
How do I troubleshoot
thanks
thanks
Led 2 and 3 flashing is normal.
Is Led 4 on ?
Did you install the windows driver ?
What card are you using ?
thank
led4 on
install driver i can see smoothie com port also access the sd
If I were a new tf card
copy firmware.bin & config.txt
restart smoothieboard
firmware was flashed successfully, the filename changed to FIRMWARE.CUR
So everything works fine now ?
What board are you using ?
led 2 3 flashing regularly sometime slow sometime fast
