Help sourcing "wheels" for rotary device?
Help sourcing “wheels” for rotary device? I’m not having any luck and I’m not for sure what to even search for. Every other part is easily and cheaply found except for these darn wheels. Anyone have any suggestions or alternatives?
@laurence_champagne You could use something like these! all you need to do is remove them from the frame and mount them on to a drive.
I turned some Derlin down on a lathe but would use these if I hadn’t.
i lasercut mine from acrylic and combined 4 layers, with the outside layers being slightly larger to create a lip.
@Domm434 inside the lip you insert a rubber band
#K40Rotary
@donkjr Off topic, but would you mind sharing a copy of your config file? I just got the cohesion board and am having trouble dialing it in. I just watched that video with the rotary and you have that thing going faster than I thought the k-40 could lol.
@laurence_champagne
What video… I am not running a rotary?
@donkjr I’m sorry, I just went back and looked. I though it was you but it was a video of someone else you shared.
@laurence_champagne no worries I do that all the time. Try searching with #K40rotary
