Help with Laser settings
Bought a made in china laser, trying to configure LaserWeb and dont have any info on what to set the Laser diameter to after loading a file.
Here are the specs from the laser I bought but dont see anything about the laser diameter.
Any help would be greatly appreciated.
Wavelength(nm):445nm-450nm
Input Voltage(v):12V
Operating Mode:CW
Cooling Mode:FAN+CASE
Transverse Model:Near to TEM00
Beam Diameter at the Aperture(mm):~6
Divergence,Full angle(mrad):<=4
Power Stability(RMS/4 hrs):<5%
Operating Temperature:-10~+35
TTL/Analog Modulation:TTL
Laser Head Dimensions(LWH):303050
Power Supply:PSU included
Expected Lifetime(hours):>5000
Package:BOX
Weight:0.3KG
The laser diameter parameter is just used to define the “pixel size” when doing raster engraving. It doesn’t realy have to match the real laser kerf. Start with a value of 0.2mm.
If the pixel density of black areas is too low, reduce the laser diameter to 0.15mm or so. You can see the laser diameter as the pixel size. The smaller the size, the higher the pixel density (and also the data rate!). If you set that value too small and the feed too hight, you will probably get stuttering moves because the data rate is quicker then the machine can handle.
