Hello everyone, I just received my smoothieboard and it looks promising so far. I am trying to setup my Delta printer with the board, it has XYZ endstops on top and the z_probe with the effector. I have couple of questions regarding Smoothieware.
I have read that I have to put firmware.bin and config.txt in root of the SD and after power off/on, the firmware.bin should turn to firmware.cur. That never happens, however, whatever change I make in config.txt, it reflects on the functioning of the printer. Meaning, for example, if I change the feedrate, I can see the difference in speed when I home or manually jog. Is that normal, I mean it working and yet not changing to .cur?
I have set the gamma_max to 320.5 (that is the height from nozzle to bed while homed). However when I manually move the z axis all the way down to the bed, I get -320.5 instead of 0. What I have noticed is that when I manually jog Z axis down/up 100mm, it moves 50 mm. Any solution?
Thanks!
