Here is a cable management system I came up with for my Eustathios v2 Spider.
Hack, modify, print, enjoy!
https://www.youmagine.com/designs/2020-extrusion-cable-management
I like it!!
Nice!
Can you add source files to your YouMagine posting?
@Bud_Hammerton I put this together in Tinkercad, which only outputs the stl/obj file.
Okay, then. I was looking for something like this, but STLs are just too hard for me to work with. I’ll see what I can do with this to convert it to a solid part. Thanks for all the effort and the design.
Update: I recreated this and exported to STEP and IGES, take them for anyone else asking for CAD files. http://1drv.ms/1QZgtx2
This was a model I didn’t know I needed until you posted, now I can see how it could simplify and clean up wire management.
I like this a lot! I was trying to think of how I might make something like this. My ideas weren’t nearly as simple.
@Bud_Hammerton thanks for making that available. I seriously need to learn a proper cad program
@Erik_Scott Thanks. I’m still working on something to transition from horizontal to vertical extrusion, more to come.
@Rick_Sollie make versions with a 45deg cut in the top, rather than horizontal, and don’t carry the clip bits up to the cut.
And since I suck at explaining things, I decided to go ahead and make a set: http://i.imgur.com/sedSiDY.png. @Rick_Sollie what do you think?
@Erik_Scott that will do the trick!
