Here is the new Double Drive fitted to the Recreus Extruder. This pushes the flexible filament down into the hot end at the fasted speeds. The prints in the last photo were printed at 100mm/s on a Witbox in #Filaflex .
Both gears are grooved around the centre to allow the filament to pass through and not be crushed or stripped but still be contained sideways.
@Steve_Wood_Gyrobot Nice solution, i have been working on this problem myself quite a bit. Is the idler hobbed as well? Ar you printing 3mm filament or 1.75?
Because I haven’t seen the need. I don’t remember the last jam I’ve had. That extra force might even cause problems. If the nozzle’s jammed, these solutions aren’t going to help. A single hobbed pulley can and has lifted a 3D printer by itself. So where’s the need for a double?
I would prefer double traction for elastic filament. It tends to buckle very easily when pushed unevenly… Currently i resolved this by guiding the filament very closely (compacto extruder), but double traction would be the alternative.
So the profile is similar to Printrbot’s version. Should be fine for flexible filaments, but I’m not crazy about the way that type of profile will deform harder filaments if there’s enough tension to do so, or the lack of grip if it doesn’t.
