here is the results from my lightpainting :) needs a little code twiddling,
here is the results from my lightpainting :slight_smile: needs a little code twiddling, someone from pjrc forums helped.
nice work! what are you using to upload an image?
it reads a bmp from the built in sd card
fiddled with the code some more. and it displays 1 image per button press. using switch case :slight_smile: need to take another few images.
Check out Harmonic light for some creative ideas on imagery and usage :slight_smile: https://www.facebook.com/HarmonicLights/
