Here's a little progress update of the ever-evolving costume running animations from Mark Kriegsman
Here’s a little progress update of the ever-evolving costume running animations from @Mark_Kriegsman and @Andrew_Tuline on the heart matrix bodice and ws2812b strip cage skirt. Just playing around with the animations on the Bluefuit LE Connect app.
https://youtu.be/2TEjBAwReXA
Looking very nice. Any issues you’ve had to solve or work around along the way?
@marmil oh my gosh so many. My biggest issue is that I’m teaching myself all of this as I go along so probably simple coding errors can throw me off. I will post the code in a couple days because I’m sure there are much simpler ways to accomplish what it’s doing. I basically had to write a separate effect for the top and skirt since one is a matrix and the other the strips. Also there were a bunch of animations that worked great in their stand alone example but that wouldn’t work in mine.
@Charity_Stolarz ​ Super, sounds like you’re learning a lot then. I would say breaking the code to separate sections for the matrix and strips was a good call as it can give you options later. Hopefully we can help you get some other animations into the mix after you post your code. Keep going!
