Heres a quick vid of a display I made for easter,
Heres a quick vid of a display I made for easter, one of 2 actually. This is made from a strip of ‘neon flex’ ws2812b leds 300 count taped to a sheet of foamboard. It was a bit pricey but I’ve found it’s a quality item and reused it in a few displays. Next year I’ll add more animations. I am looking for a smaller cross section neon flex strip for future projects it would be nice to have a tighter bend radius and not as stiff to work with. It weighs about 5lbs as well!
That looks quite eggscelent.
Very cool, which neon flex are you using?
https://m.aliexpress.com/item/32823372160.html?trace=wwwdetail2mobilesitedetail&productId=32823372160&productSubject=5m-DC5V-WS2813-addressable-led-neon-flexible-pixel-light-RGB-full-color-60leds-m-with-60pixels&spm=a2g0s.9042311.0.0.UzBaS9. But the 5v version is dim in the middle if full white even if powered from both ends so I suggest the 12v version.
Also it’s running from an Adafruit Huzzah Esp8266 breakout board + level shifter module. It runs quite smoothly.
@Stephen_Kramer I’ve got some APA102 neon strip somewhere. I’ve tested it bt not made anything with it yet. I got it from Ray Wu who has a wide range…
https://www.aliexpress.com/store/701799/search?origin=y&SearchText=neon
Thanks that’s where I got it.
