Hey all, great to see your builds, I have finished mine though I have an issue with the axle/gears, I have tried printing them with .01 mm res and no matter how many times I try with axle and gears they aren’t perfect enough for me. If anyone knows of a Steel axle and gears that would work it would be great if anyone could send me a link. The other issue is that the motor I am using will strip the gears. Thanks!
Edit: For the RC F1
https://pinshape.com/3d-printed-object/1261-openrc-formula-1-car or https://www.thingiverse.com/make:184326
I have a full list of parts to convert it over to Tamiya f104 running gears. The list is in the comments section on the Pinshape link.
So I bought the axle, rims, bearings, and tires, however when I go to put the wheel on the side not with the tire on it there is nothing to attach it to, is there a part not included on your list on your build or am I missing parts? @brett_turnage
Did you buy the motor mounts as well? I didn’t see that in your list and you’re going to need those. http://www.tqrcracing.com/shop/product_view.asp?p_id=3555
Without the motor mounts the gears won’t mesh up.
@brett_turnage
Yes I do have them, I just forgot to put them in the list, I still have no way of mounting one of the wheels to the axle, I am probably just doing something wrong. The end of the axle without the gears is just flattened out some, it doesn’t have the hex shape that the other end has.
Oh I know what’s going on. One side has the differential kit. The other side has a connector that fits on. Give me a second and I’ll post the part and hopefully it is in your list of parts. I’ll post the manual to help you put things together
@brett_turnage Thanks, I actually have the whole real axle assembled minus the end with out the differential.
You’re looking for the lock nut. It’s ba17 Tamiya, that’s the part number.). It should’ve come in the differential kit.
Here’s the manual if you don’t have it yet.
Can you post a link to which differential kit you have so I can see if it has the part?
In this generic picture is the black piece on the left http://www.tqrcracing.com/shop/product_view.asp?p_id=1412
I think in the Tamiya kit it is blue or silver.
@brett_turnage
https://www.tqrcracing.com/shop/product_view.asp?p_id=8156
It appears to only have one, I got the link from your pinshape post.
Then it’s the blue part that is attached to the shaft.
@brett_turnage
I’m confused as to what you are saying, here’s what mine looks like right now. http://i.imgur.com/bpPBpRN.jpg
The only part I have left is a little tiny Grub screw that goes in the end.
Okay thanks for the pic. Let me get to a computer in an hour and I’ll circle the part that looks to be missing.
@brett_turnage
Thanks!
Yah I did miss a part. Sorry about that https://www.tqrcracing.com/shop/product_view.asp?p_id=2305
@brett_turnage
Do I need anything else? I saw silver pieces in your picture.
@brett_turnage
Also did the mounts fit on the base well or did you have to make a new one?
Yah I did have to cut the base to make it sit square because the motor mounts hold the motor lower than its printed counter part.
I made carbon base for mine. I was hoping to have it up by now, but if you would like one it’s $35.
Can you send pictures of it? I was thinking of laser cutting myself some sort of base.
