hey all I put these in Fusion 360 using openbuilds .step files library.
hey all I put these in Fusion 360 using openbuilds .step files library. this is still work in progress. I don’t have access to CNC so no custom plate here… inside 360 I had all parts textured but exporting to sketchfab is a bit tricky and seems like I lost all the texture I had. not sure what file format should be. anyone has any experience with sketchfab?
Originally shared by Step Cia
Alright work in progress… bunch of openbuild parts together :slight_smile:
https://skfb.ly/RZLL
Instead of exporting what I guess is a STL file to sketchfab you can use Autodesk’s A360 to share a STEP model (that will retain most features from your original design). https://a360.autodesk.com/viewer/
You’re right I did STL export of tye whole thing… I knew I did something wrong :slight_smile: I’ll check out the step exporter thx
Reminds me how my @M_Prime ​ One. Works. However in a stiffer yet more expensive package.
What would be the build area size ?
The z is fixed to a wall at both bottom and top. Build area I’m going to reuse my prusa y assembly so it’s going to be around 215x215 although the x arm still have plenty of space to travel beyond build area.
