Hey all!
Love this group! I recently started having fun with arduino, ws2812b leds and FastLed thanks to all the tutorials out there. I’ve started a home automation project, arduino controlled with voice through android+bluetooth,
Everything works great at this stage but I can’t add a rainbow effect (color fading in general) with FastLed into my code as a “function” I can call upon like the ones I already have in the code, I’ve tried a few times from some code samples on here, but keep failing, is it possible? It’s all fairly new to me so no expert on the coding side. Any help/tips to push me into the right direction?
Thanks a ton!
Wow thats really kind of you! I really appreciate posting it with a code example! I just tried it and it compiles nicely, although the rainbow doesn’t “cycle”.
If I put up the serial monitor and trigger “rainbow” over and over again the colors change, but If I call for the function and leave it be its just static, hmm, been trying to play around and test but to no success unfortunately
EDIT: if I put fill_rainbow( livingroom, MAX_NUM_LEDS, gHue, 17); in void loop() then it shows the rainbow animated and happy, but not when I call it from void rainbow() function so is it not possible calling it on demand?
Yes it’s there, but it’s still not working when called on-demand as a “function” like the other light-presets in the code, as you can see in the code on the first reply. It only works if both fill_rainbow and every_n_milliseconds are in Void loop() unfortunately
Problem solved thanks to a collegue who’s a programmer!
Here’s the fully working code, the short version of it, with some booleon action going on in there its finaly all working great!
Thanks for the input and help everyone! http://pastebin.com/RafnvxVz
