Hey
Anybody has a correct setting for Corel x6 to export SVG to lw4? Tried every Option, but LW freezes as soon as i try to open the document. Other svg are working. Am i missing something or is this a Corel Problem?
Can you post the troubled file?
Yes there are definitely “Corel problems” aka things that Corel likes to do it’s own way. I don’t know much about it but it’s not the first time I’ve seen something like this mentioned.
Here is the file
it´s working when i import the corel svg to AI, and export it back,… but thats not it should be
I get the same issue but its intermittent and sometimes will load if given time. I think its the errors popping up in the gcode box relating to the path tags.
I’ve given up on direct Corel to LW (until they do a CDR module anyway) and just open the CDR in Inkscape and save it as SVG from there… (And I’m not the only one…)
Ok, i thought so that corel would make problems, but i hoped that there is any solution… but thanks for the info. at least i know now that it´s not my fault. so i will make it also with inkscape
