Hey everyone, Hope everyone's chrismas was well..
Hey everyone,
Hope everyone’s chrismas was well…
I was wondering if anyone would help me with some code to light up a strip with a motion sensor. The main objective is to show the code “Holiday_Twinkle” when the PIR sensor is high. Don’t display when low.
If motion wasn’t detected for > 2 minutes
turn off led strip.
Here is the code that I have been fumbling with:
// Twinkling ‘holiday’ lights that fade up and down in brightness.
// Colors are chosen from a palette; a few palettes are provided.
// The basic operation is that all pixels stay black until they
// are ‘seeded’ with a relatively dim color. The dim colors
// are repeatedly brightened until they reach full brightness, then
// are darkened repeatedly until they are fully black again.
// A set of ‘directionFlags’ is used to track whether a given
// pixel is presently brightening up or darkening down.
// For illustration purposes, two implementations of directionFlags
// are provided: a simple one-byte-per-pixel flag, and a more
// complicated, more compact one-BIT-per-pixel flag.
// Darkening colors accurately is relatively easy: scale down the
// existing color channel values. Brightening colors is a bit more
// error prone, as there’s some loss of precision. If your colors
// aren’t coming our ‘right’ at full brightness, try increasing the
// STARTING_BRIGHTNESS value.
// -Mark Kriegsman, December 2014
#include “FastLED.h”
#define LED_PIN 7
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
#define NUM_LEDS 10
CRGB leds[NUM_LEDS];
#define digitalPin 2 // pin that the PIR sensor is attached to
//const int digitalPin = 2; // pin that the PIR sensor is attached to
const int threshold = 400; // an arbitrary threshold level that’s in the range of the analog input
#define MASTER_BRIGHTNESS 75
#define STARTING_BRIGHTNESS 64
#define FADE_IN_SPEED 32
#define FADE_OUT_SPEED 20
#define DENSITY 255
void setup() {
delay(3000);
pinMode(LED_PIN, OUTPUT);
pinMode(digitalPin, INPUT);
FastLED.addLeds<LED_TYPE,LED_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(MASTER_BRIGHTNESS);
void loop() {
int = digitalRead(digitalPin);
if ( digitalPin > threshold) {
chooseColorPalette();
colortwinkles();
FastLED.show();
FastLED.delay(20);
void colortwinkles()
// Make each pixel brighter or darker, depending on
// its ‘direction’ flag.
brightenOrDarkenEachPixel( FADE_IN_SPEED, FADE_OUT_SPEED);
// Now consider adding a new random twinkle
if( random8() < DENSITY ) {
int pos = random16(NUM_LEDS);
if( !leds[pos]) {
leds[pos] = ColorFromPalette( gPalette, random8(), STARTING_BRIGHTNESS, NOBLEND);
setPixelDirection(pos, GETTING_BRIGHTER);
void brightenOrDarkenEachPixel( fract8 fadeUpAmount, fract8 fadeDownAmount)
for( uint16_t i = 0; i < NUM_LEDS; i++) {
if( getPixelDirection(i) == GETTING_DARKER) {
// This pixel is getting darker
leds[i] = makeDarker( leds[i], fadeDownAmount);
} else {
// This pixel is getting brighter
leds[i] = makeBrighter( leds[i], fadeUpAmount);
// now check to see if we’ve maxxed out the brightness
if( leds[i].r == 255 || leds[i].g == 255 || leds[i].b == 255) {
// if so, turn around and start getting darker
setPixelDirection(i, GETTING_DARKER);
CRGB makeBrighter( const CRGB& color, fract8 howMuchBrighter)
CRGB incrementalColor = color;
incrementalColor.nscale8( howMuchBrighter);
return color + incrementalColor;
CRGB makeDarker( const CRGB& color, fract8 howMuchDarker)
CRGB newcolor = color;
newcolor.nscale8( 255 - howMuchDarker);
return newcolor;
// For illustration purposes, there are two separate implementations
// provided here for the array of ‘directionFlags’:
// - a simple one, which uses one byte (8 bits) of RAM for each pixel, and
// - a compact one, which uses just one BIT of RAM for each pixel.
// Set this to 1 or 8 to select which implementation
// of directionFlags is used. 1=more compact, 8=simpler.
#define BITS_PER_DIRECTION_FLAG 1
#if BITS_PER_DIRECTION_FLAG == 8
// Simple implementation of the directionFlags array,
// which takes up one byte (eight bits) per pixel.
uint8_t directionFlags[NUM_LEDS];
bool getPixelDirection( uint16_t i) {
return directionFlags[i];
void setPixelDirection( uint16_t i, bool dir) {
directionFlags[i] = dir;
#endif
#if BITS_PER_DIRECTION_FLAG == 1
// Compact (but more complicated) implementation of
// the directionFlags array, using just one BIT of RAM
// per pixel. This requires a bunch of bit wrangling,
// but conserves precious RAM. The cost is a few
// cycles and about 100 bytes of flash program memory.
uint8_t directionFlags[ (NUM_LEDS+7) / 8];
uint16_t index = i / 8;
uint8_t bitNum = i & 0x07;
// using Arduino ‘bitRead’ function; expanded code below
return bitRead( directionFlags[index], bitNum);
// uint8_t andMask = 1 << bitNum;
// return (directionFlags[index] & andMask) != 0;
// using Arduino ‘bitWrite’ function; expanded code below
bitWrite( directionFlags[index], bitNum, dir);
// uint8_t orMask = 1 << bitNum;
// uint8_t andMask = 255 - orMask;
// uint8_t value = directionFlags[index] & andMask;
// if( dir ) {
// value += orMask;
// directionFlags[index] = value;
// read the value of the potentiometer:
int analogValue = analogRead(analogPin);
//chooseColorPalette();
//colortwinkles();
CRGBPalette16 gPalette;
// if the analog value is high enough, turn on the LED:
if (analogValue > threshold) {
// digitalWrite(LED_PIN, HIGH);
FastLED.show();
FastLED.delay(20);
else {
digitalWrite(LED_PIN, LOW);
void chooseColorPalette()
uint8_t numberOfPalettes = 1;
uint8_t secondsPerPalette = 10;
uint8_t whichPalette = (millis()/(1000*secondsPerPalette)) % numberOfPalettes;
CRGB r(CRGB::Red), b(CRGB::Blue), w(150,150,55), g(CRGB::Green), W(CRGB::White), l(0xE1A024);
switch( whichPalette) {
case 0: // Red, Green, and White
gPalette = CRGBPalette16( r,r,r,r, r,r,r,r, g,g,g,g, w,w,w,w );
break;
// case 1: // Blue and White
//gPalette = CRGBPalette16( b,b,b,b, b,b,b,b, w,w,w,w, w,w,w,w );
// gPalette = CloudColors_p; // Blues and whites!
// break;
// case 2: // Rainbow of colors
// gPalette = RainbowColors_p;
// break;
// case 3: // Incandescent “fairy lights”
// gPalette = CRGBPalette16( l,l,l,l, l,l,l,l, l,l,l,l, l,l,l,l );
// break;
// case 4: // Snow
// gPalette = CRGBPalette16( W,W,W,W, w,w,w,w, w,w,w,w, w,w,w,w );
// break;
enum { GETTING_DARKER = 0, GETTING_BRIGHTER = 1 };
#endif
Hey Jason, just looking at the loop() function, I may have found a problem. “int” is a type of variable, not an actual variable, so your first two lines should be more like:
int pin_reading = digitalRead(digitalPin);
if ( pin_reading > threshold) {
My advice is to start out simple and add to your code as you go along. Just getting an LED to light up based on a sensor reading seems like your most basic problem, so instead of calling these other complex functions in the loop function, just light up a single LED if the sensor is high.
yea i got the simple stuff figured out. Having the sensor continue looking for movement while led is in delay is the challenge.
