Hey Everyone! So this is my first MAJOR LED project.
Hey Everyone! So this is my first MAJOR LED project. I;ve neer realyl worked with much circit work or coding at all so I’m a tad stuck on coding.
To start, I’m using all products frin Adafruit.com:
  • NeoPixel Digital RGB LEDs, 30 LEDS a strip
  • Pro Trinket 5V 16 MHx
  • PowerBoost 500 Charger
I am also using Arduino to program my LEDs.
I’m Cospling as Junkrat from over watch and adding LEDs into the tips to make them look like they are on fire. I got everything to work perfect (A proud moment tears were shed haha).after days of fidling with different codes, patterns and even the boyfriend helping. I find came across The Cosmic Turtal coding on adafruit (The Code | Neopixel Cosmic Turtle Necklace | Adafruit Learning System) IT WAS ALMOST PERFECT. So far I;ve figured out how to Speed the pattern up and changing a fade setting to make it flicker more like fire. My ONLY problem is the white color showing up in the coding. I can’t figure out how to change it so the white is gone and I keep the reds,yellows and oranges. Any help would be greatly appercited. Dumb it down if you have to haha I’m still new to all of this!
Below is the coding I’m using where I am in this:
#include “FastLED.h”
#define LED_PIN 6
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
#define NUM_LEDS 2
CRGB leds[NUM_LEDS];
CRGBPalette16 currentPalette;
TBlendType currentBlending;
// Twinkling ‘holiday’ lights that fade up and down in brightness.
// Colors are chosen from a palette; a few palettes are provided.
// The basic operation is that all pixels stay black until they
// are ‘seeded’ with a relatively dim color. The dim colors
// are repeatedly brightened until they reach full brightness, then
// are darkened repeatedly until they are fully black again.
// A set of ‘directionFlags’ is used to track whether a given
// pixel is presently brightening up or darkening down.
// For illustration purposes, two implementations of directionFlags
// are provided: a simple one-byte-per-pixel flag, and a more
// complicated, more compact one-BIT-per-pixel flag.
// Darkening colors accurately is relatively easy: scale down the
// existing color channel values. Brightening colors is a bit more
// error prone, as there’s some loss of precision. If your colors
// aren’t coming our ‘right’ at full brightness, try increasing the
// STARTING_BRIGHTNESS value.
// -Mark Kriegsman, December 2014
#define MASTER_BRIGHTNESS 30 // change this to change overall brightness
#define STARTING_BRIGHTNESS 128 // change this to change maximum brightness
#define FADE_IN_SPEED 10 // lower number fades in slower
#define FADE_OUT_SPEED 2// higher number hangs around longer
#define DENSITY 255
void setup() {
delay(3000);
FastLED.addLeds<LED_TYPE,LED_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(MASTER_BRIGHTNESS);
currentBlending = LINEARBLEND;
CRGBPalette16 gPalette;
void loop()
//Un-comment the line with the colors you like best
//gPalette = OceanColors_p;
//gPalette = RainbowColors_p;
gPalette = HeatColors_p;
//gPalette = PartyColors_p;
//gPalette = CloudColors_p;
//gPalette = RainbowStripeColors_p;
colortwinkles();
FastLED.show();
FastLED.delay(0); // change this to change overall speed
enum { GETTING_DARKER = 0, GETTING_BRIGHTER = 1 };
void colortwinkles()
// Make each pixel brighter or darker, depending on
// its ‘direction’ flag.
brightenOrDarkenEachPixel( FADE_IN_SPEED, FADE_OUT_SPEED);
// Now consider adding a new random twinkle
if( random8() < DENSITY ) {
int pos = random16(NUM_LEDS);
if( !leds[pos]) {
leds[pos] = ColorFromPalette( gPalette, random8(), STARTING_BRIGHTNESS, NOBLEND);
setPixelDirection(pos, GETTING_BRIGHTER);
void brightenOrDarkenEachPixel( fract8 fadeUpAmount, fract8 fadeDownAmount)
for( uint16_t i = 0; i < NUM_LEDS; i++) {
if( getPixelDirection(i) == GETTING_DARKER) {
// This pixel is getting darker
leds[i] = makeDarker( leds[i], fadeDownAmount);
} else {
// This pixel is getting brighter
leds[i] = makeBrighter( leds[i], fadeUpAmount);
// now check to see if we’ve maxxed out the brightness
if( leds[i].r == 255 || leds[i].g == 255 || leds[i].b == 255) {
// if so, turn around and start getting darker
setPixelDirection(i, GETTING_DARKER);
CRGB makeBrighter( const CRGB& color, fract8 howMuchBrighter)
CRGB incrementalColor = color;
incrementalColor.nscale8( howMuchBrighter);
return color + incrementalColor;
CRGB makeDarker( const CRGB& color, fract8 howMuchDarker)
CRGB newcolor = color;
newcolor.nscale8( 255 - howMuchDarker);
return newcolor;
// For illustration purposes, there are two separate implementations
// provided here for the array of ‘directionFlags’:
// - a simple one, which uses one byte (8 bits) of RAM for each pixel, and
// - a compact one, which uses just one BIT of RAM for each pixel.
// Set this to 1 or 8 to select which implementation
// of directionFlags is used. 1=more compact, 8=simpler.
#define BITS_PER_DIRECTION_FLAG 1
#if BITS_PER_DIRECTION_FLAG == 8
// Simple implementation of the directionFlags array,
// which takes up one byte (eight bits) per pixel.
uint8_t directionFlags[NUM_LEDS];
bool getPixelDirection( uint16_t i) {
return directionFlags[i];
void setPixelDirection( uint16_t i, bool dir) {
directionFlags[i] = dir;
#endif
#if BITS_PER_DIRECTION_FLAG == 1
// Compact (but more complicated) implementation of
// the directionFlags array, using just one BIT of RAM
// per pixel. This requires a bunch of bit wrangling,
// but conserves precious RAM. The cost is a few
// cycles and about 100 bytes of flash program memory.
uint8_t directionFlags[ (NUM_LEDS+7) / 8];
uint16_t index = i / 8;
uint8_t bitNum = i & 0x07;
// using Arduino ‘bitRead’ function; expanded code below
return bitRead( directionFlags[index], bitNum);
// uint8_t andMask = 1 << bitNum;
// return (directionFlags[index] & andMask) != 0;
// using Arduino ‘bitWrite’ function; expanded code below
bitWrite( directionFlags[index], bitNum, dir);
// uint8_t orMask = 1 << bitNum;
// uint8_t andMask = 255 - orMask;
// uint8_t value = directionFlags[index] & andMask;
// if( dir ) {
// value += orMask;
// directionFlags[index] = value;
#endif
You need to create your own ‘custom’ palette instead of the ‘built-in’ ones.
For example, replace the following line…
with the following lines…
  gPalette = CRGBPalette16( CRGB::Black, CRGB::Red, CRGB::DarkOrange, CRGB::DarkOrange,
CRGB::DarkOrange, CRGB::DarkOrange, CRGB::DarkOrange, CRGB::Orange,
CRGB::Orange, CRGB::Orange, CRGB::Orange, CRGB::Yellow,
CRGB::Yellow, CRGB::Yellow, CRGB::Yellow, CRGB::Yellow);
That is something I cut and pasted from an adaptation I did a while ago when I also thought the whites were too bright.
You can play with any of the color names listed to tune it to your own liking.
The other thing you can do is avoid the part of the palette that gets too white. The call to GetColorFromPalette chooses the color by calling random8(), which will give you any of the 256 colors. You can map this range to a smaller range in a few different ways. The simplest is just to divide it by 2: pass random8()/2 into that function.
@JP_Roy Thank you do much! This worked very well! Exactly what I needed!
@Michelle_White I remember also that I replaced the white with grey or was it dark grey !? It helped to dull the white but still provide a ‘hotter’ color than yellow.
You may also look at the very bottom of the following wiki that lists all the preset color names that can readily be used:
You could improve the custom palette by replacing the color names that are repeated 4 or even 5 times with intermediate colors to provide a better range of colors.
A more precise option could be using the form…
CRGB( 255, 100, 0 ), instead of using names.
@JP_Roy I believe there are also routines to create a palette by interpolating between two colors.
I actually manage to work it around to . remove all whites/greys. I didnt want to have any whites or greys. as it is ment to repicate flames. But it all worked out!
