Hey guys can anyone help im engraving an image but it engraves inverted i inverted it in coral but the machine goea haywire
Can you post a picture of the image?
There are two options in the CorelLaser engraving panel for Sunken (or not). One will cause it to engrave inverted. Check what that tickbox is set to (up the top centre if I recall correct).
Thank you i will give that a try
