Hey guys, having a little trouble with CorelLaser doing two passes on all cuts?
Hey guys, having a little trouble with CorelLaser doing two passes on all cuts? have tried adjusting all cut to hairline and 0.1mm, as advised is some other posts, but still getting double passes.
Veiw what ever you are cutting in wirer view, if converted image to a vector most likly to have 2 lines close together that you can not see unless you change veiw to wire veiw and zoom in
Hit wireframe, and zoomed into max 1600% and still only one line, they are vector files for Illustrator if that’s any help??
edit to add: see “repeat” is set to 1 in settings, should that be on 0?
I use e cut to remove hidden lines,works very well best $70 i have spent.
simplest way is dont use lines for cutting, use solid shapes with cutouts where necessary. it will cut the outline of that solid shape.
