Hey guys. I am buying my first 3d printer. A Tevo Tarantula. I bought it from Aliexpress and it has just shipped from china. I am planning to create a startup where I design, and build my prototype engineered products in ABS (it has to retain integrity even put inside a car parked in scorching sun) to end customers.
I have done some research into 3d printing in general and I know that I have to get bed levelled and setup printer right, clean the nozzle …
I have a few questions.
How important is it to print supports for my X, Y and Z axis carriages? I don’t need super accurate 3d prints with smooth surface.
I want to print very fast. I know there will be layer imperfections and grainy boundaries. Can I finish my products by blowing them with heat gun to smoothen the surface?
Is ABS really that difficult to work with? I will be printing parts of atleast 3mm thickness. So, do I really need to enclose my 3d printer to retain the heat or is it OK to leave the printer open?
Is ABS the most suitable material or is there anything new. Last I checked on Makers Muse youtube channel, I found ABS is heat resistant. Are there any new materials?
I live in a place where power outages. So, if the power cuts off, is there a resume option? If not, should I buy a 24 volt battery system and directly connect my printer to it or should I still convert to AC and use the adapter? (My noobness shining through)
Are there any tips in general for a noob like me?
