Hey guys, I am trying to use Glediator matrix control software to run animations
Hey guys,
I am trying to use Glediator matrix control software to run animations on my matrix from an SD card.
I am running into what I think is a pixel mapping issue… The animation displays correctly when running Glediator via serial but incorrectly via SD card:
Serial - https://drive.google.com/file/d/1CDm-tU63rJFjnHoIAFTb-lsbpt3kpM5E/view
SD card - https://drive.google.com/file/d/1xSDxnQ1uYjWDdSVP_DZijREl6-0u_u-L/view
More info and sketch files in this thread:
https://forum.arduino.cc/index.php?topic=549375.0
Not specifically FastLED per say but I thought you guys might have some experience with this software.
Thanks,
Austin
If i remember correctly there is an issue with the mapping when you ‘record’ and when its live being pushed through a PC. On i project I used it on I eventually went with a Raspi embedded in the structure pumping live data out to the matrix in lieu of recorded scenes. Check this link and see if it helps with your issue. https://www.youtube.com/watch?v=Vu5Edp-siPc
