Hey guys i had a question.
So i tried loading a file from thingiverse and converting it to gcode using cura but the blue progress bar will just load completely and the extruder and print bed will just get hotter and hotter.
Can anyone help me?
What printer? And it heats well above the printing temperature?
Did you look gcode file what is inside if you have only few lines then maybe cura didn’t do sliceing correctly. Take printscreen of gcode file you can open it with notepad.
@Adam_Steinmark Monoprice select mini V2, and not but if i left it going it could get over 100°c (i only set the print bed to 70°c)
@Benjamin_Lukman No i didn’t i guess i should check, i will when i find time. (Homework, school, etc.)
