Hey guys, I used FastSPI2 some while ago and I was delighted to find
Hey guys,
I used FastSPI2 some while ago and I was delighted to find a template parameter that held the number of my spi select pin. As I am using an the WIZ812MJ along with my LEDs, I made a custom SPI “device” that made use of the active-low select signal.
With FastLED I understand that the select pin option is gone, I merely find settings for data and clock pin. Any tips on reviving my select pin?
Thanks a lot.
I basically cut off work on it because nothing was using it - you can manually select/release before calling show. (You’re the first person in 3 years to notice it gone/comment on it :slight_smile:
