hey guys. I was trying to print today after I came home from school, but cure wouldn’t connect to my printer. my laptop says that there is a device connected and runs setup like normal, but cura wont recognize the printer. it was working over the weekend and I just noticed this now. and thoughts one what’s the problem?
Check to make sure the USB device is showing up the same, if different, you may need to change the serial port setting in Cura?
@Bruce_Lunde still nothing. any other ideas
Have you checked the Baud rate?
Could be that they are at different speeds on the USB device and Cura.
@Chris_Dunleavy well i havent touched anything on my printer or cura but ill check anyways
@Piet_Fourie ya i did notice. Ill check
