Hey guys! I’m running the break in gcode but its only operating in the 1st quadrant of the bed. Any ideas? I haven’t made a S3D profile yet, but if someone would send me one as a starting point it would be greatly appreciated
UPDATE: Ran it again… Now it is (and I) throughly confused… It only jerks around in the center… Could it have somthing to do with the ACCEL? I set it down to 200. (It only this this once, it always does the 1/4 thing…)
You likely are running higher microstepping drivers. So you will need to adjust the steps/mm in the firmware config to add more steps (more distance). That’s why you are essentially seeing a scaled down version of the break in gcode.
Did you go with the sd6128 drivers. If so those are 1/128 microstepping versus the 1/32 microstepping on the standard configuration.
@Eclsnowman Yup! I looked at the smoothie settings and set the steps per mm right. Got the Z axis in and I am running the break in code now Thanks for the help! P.S. do you think you could send me your S3D profile for the Eustathios? It would be helpful as a starting platform.
@Eclsnowman PLA, PETG, ABS, (ninja flex if you have it). I know ninja flex will be like pushing a rope uphill, but I want to try anyways Thanks so much!
@Stefano_Pagani Sorry for the long delay. I just kept forgetting. Give these a whirl. Please note I tried to setup some basic ones. But I almost always tune every print specific for the printed parts feature geometry. But this should be some good medium quality settings. Not too slow, not too fast:
