So since I know this community is Most likely to use azteeg x5 mini does anyone have any idea how to get a reprap discount controllers sdcard slot to work on it. I have the display fully working and it recognizes when I inserted a card but it never shows any data on he card just blank
I seem to recall them saying once that using the smart controller’s slot would conflict with the on-board slot. You might have to settle for one or the other.
YOu have the SD pins lines in your config and are they wired in the right place ?
There’s a guide for the x5 mini 1.1. You don’t need the adapter but this page shows your where is what: http://smoothieware.org/panel#toc8
@Maxime_Favre I can’t find a breakdown of the adapter if I could then I could just follow the pins like I did for the 1.0 guide but the 1.0 guide leaves out the SD card
